API File.NVM.WriteByte
Revision as of 11:55, 16 January 2023 by Wiki bot (talk | contribs)
WriteByte
Writes a single byte to the NVM multiple times
- HANDLE FileHandle
The handle of an open file
- ULONG Address
Position in the file in bytes
- BYTE Data
Array of data to write to the file
- BYTE Count
Number of times to write the byte in sequence
- ULONG Return
  • Declare a variable 'result' of type ULONG
  • Add to a calculation icon:
    result = ::File.NVM.WriteByte(filehandle, address, data, count)
