Component: GLCD (ST7567) SPI NOBUFF (Graphical Monochrome)
Revision as of 08:57, 27 April 2026 by Wiki bot (talk | contribs)
Version 1.5
Category Graphical Monochrome
GLCD (ST7567) SPI NOBUFF component
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Not for public release.
Version information
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
Goto_XY
Goto_XY
- BYTE X
- BYTE Y
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
Write_Command
Write_Command
- BYTE Command
Write_Data
Write_Data
- BYTE data
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
Clock Pin
A0
CS
Chip select pin
Reset
Fonts
Font Count
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
LCDVersion
Simulation Mode
Display Type
Physical Orientation
Component Label
Component Label Scale
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7567_SPI_NoBuffer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7567_SPI_NoBuffer.fcfx
