Component: Infrared Array AMG88xx (Light)
Revision as of 10:25, 20 October 2023 by Wiki bot (talk | contribs)
Category Light
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Please click here to download the component source project: FC_Comp_Source_AMG88.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AMG88.fcfx
ClearInterrupt
ClearInterrupt
Clear any triggered interrupts
Sets up the I2C interface and initialises the sensor.
ReadPixel
ReadPixel
Reads the temperature of a single pixel value from the last SamplePixels call.
- BYTE Index
Pixel to read. Range: 0 - 63
- FLOAT Return
ReadThermistor
ReadThermistor
Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value
- FLOAT Return
SamplePixels
SamplePixels
Reads Infrared sensor values
SetInterrupt
SetInterrupt
Allows the interrupt pin to be enabled or disabled.
- BOOL Mode
0 = Disabled / 1 = Enabled
SetInterruptLevels
SetInterruptLevels
Set the interrupt levels. Interrupt when going above High or interrupt when going below Low.
- FLOAT High
Range: -1023 to 1023
- FLOAT Low
- FLOAT Hysteresis
Range: -1023 to 1023 ( Recommend 0.95 * High )
SetInterruptMode
SetInterruptMode
Set the interrupt to either absolute value or difference mode
- BOOL Mode
0 = Difference / 1 = Absolute
SetMovingAverageMode
Set the moving average mode on or off.
- BOOL Mode
0 = Off, 1 = On
Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
API
