Component: LED Mono Custom (LED)
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Version 9.0
Category LED
LED Mono Custom component
Customisable LED indicator for both embedded and PC Developer.
Version information
8, 1.0, 01-07-25, MW,User Lable Text not changed with Handle. Added Rename event
 9, 1.0, 27-08-25, MW, improved functionality, added Hidden option for handle & bug fixes
SetState
SetState
Sets the state of the LED, accounting for the polarity.
- BOOL State
1=On, 0=Off
TurnOff
TurnOff
TurnOn
TurnOn
Function
Simulation Only
LED Settings
Connection
Component Label
Component label position
Label Colour
Polarity
Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Pin label position
Type
Colour
Style
The image to use
Filename
The location of an external image file
Vertical Alignment
Horizontal Alignment
Lock Aspect
The image to use
Filename
Vertical Alignment
Lock Aspect
Please click here to download the component source project: FC_Comp_Source_LED_Mono_Custom_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Mono_Custom_2dgi.fcfx
