Component: Input ADC (DSP Inputs)
Revision as of 16:34, 17 May 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Input ADC component
Allows the values from a buffer to be assigned driectly from an analog enabled pin. Either a single sample at a time or a number of samples. Auto scales the digital value to fill the entire range of the specified buffer type.
Please click here to download the component source project: FC_Comp_Source_DSP_ADCInput.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_ADCInput.fcfx
AddSample
AddSample
Adds a single ADC sample to the current location in the specified buffer. If Auto Scale is enabled then the sample will be scaled to correctly fit inside the buffer. Auto increments current location.
AddSampleArray
AddSampleArray
- UINT SampleDelay
Number of us in between each sample.
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Settings
Bit Depth
Maximum number of bits for each ADC sample.
VRef option
Conversion speed
Acquisition cycles
Remap Values
Map the analog input range to a selected output range.
Mapping
Input Full Range
Selects if the entire range of the ADC is mapped. Yes: Use the full ADC range No: Use a custom ADC range
Input Min
Min value provided by the ADC input
Input Max
Max value provided by the ADC input
Output Min
Min value to output
Output Max
Max value to output
Simulation Slider
Show Slider
Allows the ADC input to be driven from a slider.
Major Tick Step
The number of minor tick marks to show a major tick mark value.
Minor Tick Step
The scale value between consecutive minor tick marks.
Label Format
