Component: ADC ADS1256 (Analog Input)
Revision as of 08:58, 9 June 2025 by Wiki bot (talk | contribs)
Category Analog Input
ADC ADS1256 component
24-bit very low noise single ended or differential ADC compatible with ADS1255 or ADS1256. ADS1255 has two single ended or one differential input. ADC1256 has eight single ended or four differential inputs.
Version information
7, 1.0, 25-10-24, BR, Minor change to try and address a problem
8, 1.0, 28-10-24, BR, Solved a problem where the sensor didn't init correctly
Sets up the SPI bus ready for communications with the sensor IC.
ReadData
ReadData
Reads the result of an ADC conversion as a binary value in the range of 0 to 16,777,215
- LONG Return
ReadDataAsVoltage
ReadDataAsVoltage
Reads the result of an ADC conversion as a floating point voltage
- FLOAT Return
ReadIO
ReadIO
Reads from the general purpose IO pins
- BYTE Mask
Range: 0 (0b0000) to 15 (0b1111)
SetupADC
SetupADC
Configures the positive and negative input channels
- BYTE PositiveChannel
0=AIN0 - 7=AIN7, 8=AINCOM
- BYTE NegativeChannel
- BYTE Gain
0=1X, 1=2X, 2=4X, 3=8X, 4=16X, 5=32X, 6=64X
WriteIO
WriteIO
Writes to the general purpose IO pins
- BYTE Mask
- BYTE Value
Type
VREF Voltage
Voltage reference used in the calculations for ReadDataAsVoltage
Data Rate
Specified the data rate in samples per second. Based on a clock rate of 7.68MHz and scales linearly with fCLKIN
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Data Ready
Sync
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_ExternalADC_ADS1256.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_ADS1256.fcfx
