Component: GLCD Colour Dummy (Misc)
Revision as of 13:09, 7 February 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Misc
GLCD Colour Dummy component
Please click here to download the component source project: FC_Comp_Source_Dummy__GLCD_Colour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Dummy__GLCD_Colour.fcfx
The Bitmap Drawer FAT component must be linked to the graphical LCD using the gLCD Object property and to the FAT component using the FAT Object property.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
Bitmap Drawer FAT Demo
The bitmap files used in the example can be found here.
Bitmap Drawer FAT Files
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0. Currently does not simulate.
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetDisplayOrientation
- BYTE Orientation
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed. Does not simulate.
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
