Component: Battery Cell Fuel Gauge (MAX1704x) (Electrical)
Revision as of 13:59, 10 June 2024 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Electrical
Battery Cell Fuel Gauge (MAX1704x) component
Provides accurate voltage and state of charge readings for one or two lithium ion cells. Based on the MAX1704x device range including: MAX17043 MAX17044 MAX17048 MAX17049
ClearAlert
ClearAlert
Clears the alert status bit, if the voltage is still below the specified threshold level then the alert interrupt pin will fire again.
Configures the I2C bus ready for communications and applies the settings defined in the properties. Also sets the default power level to awake. Returns 1 if the module is detected 0 if the module is not found
ReadStateOfCharge
ReadStateOfCharge
Reads the SOC and returns as a floating point value in % between 0 and 100
- FLOAT Return
ReadStateOfChargeByte
Reads the SOC and returns as a byte value in % between 0 and 100
ReadVoltage
ReadVoltage
Reads the voltage and returns as a floating point value in Volts.
- FLOAT Return
SetPowerMode
SetPowerMode
Allows the device to be put to sleep and woken from sleep.
- BOOL Mode
0=Awake, 1=Sleep
Settings
Cell Count
Set the chip type used to determine if you have 1S or 2S cells connected.
Voltage Per Bit
Alert Threshold
Sets the SOC level where the Alert pin will fire which can be used to trigger an interrupt. Alert status needs to be reset using the ClearAlert component macro.
Config Value
Specific to the lithium charcteristics of the cell. 0x97 is the default value.
I2C Settings
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Sim Comms
API
Please click here to download the component source project: FC_Comp_Source_Battery_Cell_Fuel_Gauge_MAX17043_17044.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Battery_Cell_Fuel_Gauge_MAX17043_17044.fcfx
