Component: Air Velocity Sensor (FS3000) (Environmental)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Environmental
Air Velocity Sensor (FS3000) component
The FS3000 provides air velocity monitoring via a digital I2C interface.
Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified.
- BOOL Return
ReadMetersPerSecond
ReadMetersPerSecond
Reads the air flow rate and returns a floating point value in meters per second
- FLOAT Return
ReadMilesPerHour
ReadMilesPerHour
Reads the air flow rate and returns a floating point value in miles per hour
- FLOAT Return
ReadRaw
ReadRaw
Reads the raw output from the air velocity sensor.
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Settings
Type
Choose which specific version of the sensor to dictate the maximum detectable air speed.
API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Air_Velocity_FS3000.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Air_Velocity_FS3000.fcfx
