Component: MIAC (dsPIC) (MIAC (dsPIC)) (Misc)
Revision as of 13:11, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Misc
MIAC (dsPIC) component
MIAC - Matrix Industrial Automotive Controller (dsPIC)
Please click here to download the component source project: FC_Comp_Source_MIAC_(dsPIC).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_(dsPIC).fcfx
DisplayClear
DisplayClear
Clears the display to white space
DisplayCursor
DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
- BYTE x
Position of the cursor in characters from left to right.
- BYTE y
The line to move the cursor to.
DisplayLight
DisplayLight
Turns the display backlight on or off
- BYTE state
DisplayStart
DisplayStart
Initialise the display ready for use
DrawGlyph
DrawGlyph
Draws a character glyph on the display at position px, py
- BYTE glyph
The glyph ident number
- BYTE px
pixel column relative to the drawing origin (top left)
- BYTE py
pixel row relative to the drawing origin (top left)
- BYTE mode
0=opaque/cleared background, 1=transparent background
DrawLine
DrawLine
Draws or clears a line from start at sx:sy to end at ex:ey
- BYTE sx
Start column position
- BYTE sy
Start row position
- BYTE ex
End column position
- BYTE ey
End row position
- BYTE state
1=active pixel, 0=cleared pixel
DrawPixel
DrawPixel
Draws, or clears, a pixel at point x,y
- BYTE px
- BYTE py
- BYTE state
state = 0 clears the pixel, else draws the pixel
DrawRect
DrawRect
Draws a rectangular box from x1,y1 to x2,y2
- BYTE x1
- BYTE y1
- BYTE x2
- BYTE y2
- BYTE state
1=draw pixel, 0=clear pixel
GetKeypad
GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
InputANALOG
InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input to read from 1 to 8.
InputANALOG_10Bit
InputANALOG_10Bit
- BYTE InputID
The input to read. From 1 to 8.
- INT Return
InputDIGITAL
InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input number from 1 to 8.
OutputOFF
OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
1 to 4 (Outputs A to D)
OutputON
OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
PrintASCII
PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
- BYTE Char
ASCII code of the character to print.
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Prints the given number to the display starting at the current cursor position and moves the cursor position.
- INT n
PrintString
PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
- STRING Str
The string to send to the display.
RelayOFF
RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn off. From 1 to 4.
RelayON
RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn on from 1 to 4.
