Component: Stepper Motor (Mechatronics)
Revision as of 13:12, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Mechatronics
Stepper Motor component
A component to drive stepper motor either using direct transistors or using an external stepper driver IC. Complete with 2D based panel simulation of the motor including coils and waveforms.
Please click here to download the component source project: FC_Comp_Source_StepperMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_StepperMotor_2d.fcfx
DecrementStep
DecrementStep
Move the motor backwards by one step.
DisableMotor
DisableMotor
Turn off the motor. It will no longer respond to any other macros.
EnableMotor
EnableMotor
Turn on the motor. This must be done before it will respond to any other macros.
GetSimAngle
GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
- FLOAT Return
IncrementStep
IncrementStep
Move the motor forward by one step.
Driver
Coil 1
Chip pin to which the first motor coil is connected.
Coil 2
Chip pin to which the second motor coil is connected.
Coil 3
Chip pin to which the third motor coil is connected.
Coil 4
Chip pin to which the fourth motor coil is connected.
Motor Setup
Step Type
Trade accuracy against torque by changing the type of stepping. Refer to the data-sheet for your chosen hardware to determine which modes your device supports.
Show Pin Labels
Label Colour
Waveforms
Allows waveforms to be auto generated on the data recorder window.
Motor Simulation
Steps Per Revolution
The number of steps it takes for the motor shaft to turn a full circle (360 degrees). Refer to the data-sheet for your chosen hardware to determine this value.
Angle Increment
Amount of change in the shaft angle when the IncrementStep / DecrementStep functions are called.
Coil Simulation
Coil Simulation
Turn coil simulation on and off.
Colour Non Active Coil
Make coil object this colour when they are NOT energised.
Colour Active Coil
Make the coil objects this colour when they ARE energised,.
