Component: Temperature (LM75B) (LM75B) (Environmental)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temperature (LM75B) component
A digital temperature sensor based around the NXP LM75B chip.
Please click here to download the component source project: FC_Comp_Source_Temperature_LM75B.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_LM75B.fcfx
Initialise to default of 11 bit resolution
ReadByte
ReadByte
Read a single byte at a specific address from the chip's internal memory.
- BYTE address
ReadFloat
ReadFloat
Reads the temperature value as a float
- FLOAT Return
ReadInt
ReadInt
Read double byte data from register at address
- BYTE address
- INT Return
Uninit
Uninit
Uninitialise and release resources
WriteByte
WriteByte
- BYTE address
- BYTE data
WriteInt
WriteInt
- BYTE address
- UINT data
Channel selection
SDA
SCL
SDA Remap Pin
SCL Remap Pin
Baud Select
Baud rate to be used
Stop Delay
Simulation Comms
Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
Number of numbered divisions shown on the thermometer scale.
I2C Data
Set whether the I2C data is displayed as decimal or hexadecimal numbers.
