Component: Marking control (Misc)
Revision as of 13:13, 7 February 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Misc
Marking control component
A control to draw markings on any component
Please click here to download the component source project: FC_Comp_Source_markings.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_markings.fcfx
BoundRange
BoundRange
Bounds a range to be between RangeStart and RangeEnd
- FLOAT Range
The unbounded range
- FLOAT Return
CalcAngRange
CalcAngRange
Decide the range value for an angle Returned value may be out of range
- FLOAT AngleDegrees
- FLOAT Return
CalcAngle
CalcAngle
Decide the angle to display at given a range value
- FLOAT RangeVal
- FLOAT Return
CalcScale
CalcScale
Decide the scale (0->1) to display at given a range value
- FLOAT RangeVal
- FLOAT Return
CalcScaleRange
CalcScaleRange
Decide the range value for a 0->1 value Returned value may be out of range
- FLOAT ScaledRange
- FLOAT Return
ClearArea
ClearArea
Clears the draw area
DrawArc
DrawArc
Draw the marks on the readout Set up the position and range with SetRange() and SetArc()
- FLOAT Radius
Scale of the radius to draw at
DrawStripX
DrawStripX
Draw the marks on the readout Set up the position and range with SetRange() and SetSpan()
- INT OffsetY
Offset to add to Y
DrawStripY
DrawStripY
- INT OffsetX
Offset to add to X
SetAngles
SetAngles
Sets the min-max angles to draw on the dial Used for setting the needle Defaults are 135 and -45
- INT Start
- INT End
SetGaps
SetGaps
Sets the min-max of the span to draw on the X/Y marks Defaults are 0 and 1
- INT Start
- INT End
SetJustify
SetJustify
- BOOL RAlign
True for right/top/outer alignment
SetMarks
SetMarks
Decides on the presentation of the dial
- INT Marks
Number of marks on the dial
- INT Subs
Number of marks before a 'main' mark - can be zero
SetRange
SetRange
Sets the min-max range to draw on the dial Used for setting the needle
- INT Start
- INT End
SetShow
SetShow
- BOOL ShowNumbers
True to show numbers on the dial, else false
- BOOL ShowMarks
Show marks
SetTarget
SetTarget
Sets the target image to draw on
- ULONG Target
- INT AreaX
The X area to draw on
- INT AreaY
The Y area to draw on
- BOOL AutoCreate
Set true to auto-create the graphic
