Component: Vibrate ( Data)
Revision as of 15:46, 27 April 2026 by SteveT (talk | contribs)
Author MatrixTSL
Category Data
Vibrate component
Component that causes the mobile device to vibrate.
Version information
1, 1.0, 21-04-26, ST, Created
Many mobile devices such as mobile phones have internal hardware which can cause the device to vibrate.
This component provides access to this and allows the device to be vibrated using a pattern of vibrations and pauses.
Vibration example
This simple example shows how to vibrate a mobile device using a set of buttons.
VibrationTest.fcweb
The web app created by this example can be viewed here: VibrationTest Example
Cancel
Cancel
Cancels any ongoing vibration
Vibrate
Vibrate
Send the preset vibration pattern to the mobile device
VibrateCustom
VibrateCustom
Send a custom vibration pattern to the mobile device
- LONG Pattern
An array of values describing the vibration pattern period
Count
The number of vibrations in the sequence
Length 1
The length of the 1st vibration (in ms)
Pause 1
The length of the pause between the 1st and 2nd vibrations (in ms)
Length 2
The length of the 2nd vibration (in ms)
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Vibrate.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Vibrate.fcsx
