Component: SRF (WirelessThings) (SRF) (Wireless)
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 6.6
Category Wireless
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
Version information
6, 6.0, 29-01-25, MW, Added the following functions: 6, 6.0, 29-01-25, MW,ChangeHWBaud SendNumber ReceiveNumber SendFloat ReceiveFloat SendByteArray ReceiveByteArray
ChangeHWBaud
ChangeHWBaud
Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE NewBaud
0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
ReceiveByteArray
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
Array to store the incoming data
- UINT NumBytes
Maximum number of bytes to try and receive
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveChar
ReceiveChar
- BYTE Timeout
- INT Return
ReceiveFloat
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
Max time in ms to wait in between bytes
- BOOL IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
- FLOAT Return
ReceiveNumber
ReceiveNumber
Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE Timeout
- BOOL IgnoreData
- LONG Return
ReceiveString
ReceiveString
Send a string of data using the SRF Module
- BYTE Timeout
- BYTE NumBytes
- STRING Return
SRFInitialise
SRFInitialise
Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping.
SendByteArray
SendByteArray
Transmits an array of bytes via the UART peripheral
- BYTE Data
Data to transmit
- UINT NumBytes
Number of bytes to send from the array
SendChar
SendChar
- INT Char
SendFloat
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT Number
SendNumber
SendNumber
Sends out a number as an ASCII String from the UART interface.
- LONG Number
SendString
SendString
- STRING Data
Sleep
Sleep
Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending)
Wake
Wake
Wake the SRF module. Includes a 10ms delay to allow radio to wake.
Sleep Mode (ATSM)
Defines which sleep mode will be used when calling the Sleep component macro.
Serial comms data rate specified in bits per second.
Onboard UART peripheral to use to perform serial commands. Software mode available but not recommended for receive applications unless combined with a pin interrupt.
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
TX Remap Pin
Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
RX Remap Pin
Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Sleep
Data Source
Simulation data source used to allow the component to connect to COM port hardware or the the data API components.
COM Port
Lists all the current available COM port hardware on your PC.
Please click here to download the component source project: FC_Comp_Source_SRF_Component_v2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SRF_Component_v2.fcfx
