Component: Timer Interrupt (Timing )
Revision as of 21:16, 27 January 2026 by Wiki bot (talk | contribs)
Version 1.1
Category Timing
Timer Interrupt component
The timer interrupt can be set to trigger a specifed User macro evey time a set time has elapsed. Time units that can be selected are: Milliseconds, Seconds, Minutes, Hours or Days Maximum milliseconds = 4294967295 Maximum seconds = 4294967. Maximum minutes = 71582, Maximum hours = 1193, Maximum days = 49 Times can be changed on the fly
Version information
1, 1.0, 06-03-25, MW, Component created
ChangeTimeDays
ChangeTimeDays
Change the interrupt time to a new time in days. Maximum days = 49 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- BYTE Days
Maximum days = 49
ChangeTimeHours
ChangeTimeHours
Change the interrupt time to a new time in hours. Maximum hours = 1193 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- UINT Hours
ChangeTimeMilliseconds
Change the interrupt time to a new time in milliseconds. Maximum milliseconds = 4294967295 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG Milliseconds
ChangeTimeMinutes
ChangeTimeMinutes
Change the interrupt time to a new time in minutes. Maximum minutes = 71582 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG Minutes
ChangeTimeSeconds
ChangeTimeSeconds
Change the interrupt time to a new time in seconds. Maximum seconds = 4294967 Timer interrupt will continue at the new rate, until TimerStop or the simuation is stopped.
- ULONG Seconds
StartTimer
StartTimer
Start timer interrupt running
StopTimer
StopTimer
Stop the timer interrupt running. Stopping the simulation, also stops the timer interrupt.
Timer Interrupt
Time Unit
The unit of time to measure
Time Period
Call Macro
User macro to be triggered every time the interrupt is triggered.
Please click here to download the component source project: FC_Comp_Source_TimerInterruptPCDev.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerInterruptPCDev.fcsx
