Component: Servo Motor (Mechatronics)
Revision as of 11:42, 26 November 2024 by Wiki bot (talk | contribs)
Version 1.1
Category Mechatronics
Servo Motor component
Base component for creating custom servo motor simulations. Recieves messages from the the 'Servo Controller' component. Macro 'SetTarget' allows external objects to be moved by the servo for mechanical simulations.
Version information
2, 1.1, 13-11-24, BR, Resized component to better fit in with other 2d motor components
GetSimAngle
GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
- FLOAT Return
Movement Type
Minimum (degrees)
Angle that the servo turns when the PWM signal is at its minimum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
Maximum (degrees)
Angle that the servo turns when the PWM signal is at its maximum. Measured from the actuator object's 'rest' position, chosen at the time of connecting the object.
Please click here to download the component source project: FC_Comp_Source_Servo_Motor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Motor_2d.fcfx
