Component: Magnetic Encoder (AS5600) (Magnetic)
Revision as of 11:42, 26 November 2024 by Wiki bot (talk | contribs)
Category Magnetic
Magnetic Encoder (AS5600) component
A precise magnetic encoder featuring 12-bit resolution and interfaced via an I2C bus.
GetStatus
GetStatus
Reads the status register testing for if the magnet is detected and in range. Bit2 = Magnet Detected, Bit1 = Magnet too weak, Bit0 = Magnet too strong Ideally the best response is 4, magnet detected and in range.
Configures the I2C bus ready for communications and applies the settings defined in the properties. Also sets the default power level to always on. Returns 1 if the module is detected 0 if the module is not found
ReadAngle
ReadAngle
Returns the angle as a floating point value between 0 and 360 degrees.
- FLOAT Return
ReadRawAngle
ReadRawAngle
Returns the angle as a raw value between 0 and 4095 representing 0 to 360 degrees.
SetPowerMode
SetPowerMode
Configures the power mode of the device.
- BYTE Mode
0=Always On, 1=5ms Polling, 2=20ms Polling, 3=100ms Polling
Settings
Hysteresis
Output Stage
Controls the functionality of the OUT pin.
Slow Filter
Fast Filter Threshold
Watchdog
I2C Settings
Channel selection
Baud Select
Baud rate to be used
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Sim Comms
API
Please click here to download the component source project: FC_Comp_Source_Magnetic_Encoder_AS5600.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetic_Encoder_AS5600.fcfx
