Component: Touch Screen (FT6X06) (Graphical Library)
Revision as of 14:32, 26 July 2024 by Wiki bot (talk | contribs)
Version 2.0
Category Graphical Library
Touch Screen (FT6X06) component
Low level routines for controlling or interacting with the FT6X06 touch screen controller IC found on a lot of common capacitive touch screen products. Also compatible with FT6x36 touch screen controller IC.
Version information
11, 1.0, 26-07-24, BR, Removed ghost greay square connection line
An example of how to sample read a capacitive touch display overlay using the component.
FT6X06 Demo
Activates the SPI peripheral and claims control over the I/O pins.
ReadCoord
ReadCoord
Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
- BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
- BYTE Index
Touch Index Range: 0 - 1
SampleSensor
SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
SetOrientation
SetOrientation
Allows the orientation to be overridden.
- BYTE Orientation
Range: 0 - 3
LinkTo
Bus Settings
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Configuration
Apply Scaling
X Pixel
Y Pixel
Flip X
Flip Y
Label used to identify the component on the panel.
Enable Interrupt
Interrupt Macro
Macro called when the simulated display fires an interrupt.
Simulate Comms
Allows the I2C communications to be simulated and piped through an API to real world hardware.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_FT6X36.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_FT6X36.fcfx
