Component: Motion ( Data)
Revision as of 16:45, 25 June 2026 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Data
Motion component
Component that provides motion data for the mobile device using its internal accelerometer
Version information
1, 1.0, 24-04-26, ST, Created
Many mobile devices contain an internal accelerometer which can report the acceleration in each of the 3 perpendicular axes - x, y and z.
This component allows access to the data provided by this sensor (if available) and can report the data with/without the contribution of the gravity force at that time.
Graphing the accelerometer output
This example shows the acceleration in the 3 axes on a chart.
DeviceMotion.fcweb
The web app created by this example can be viewed here: DeviceMotion Example
Using the Motion component with a callback
The is a similar example to above, but this one uses a callback function to retrieve the acceleration data on a regular basis.
DeviceMotionWithCallback.fcweb
The web app created by this example can be viewed here: DeviceMotionWithCallback Example
GetAcceleration
GetAcceleration
Returns the device's acceleration in the specified direction
- LONG Axis
The axis to use (0=x, 1=y, 2=z)
- BOOL Compensate
Set true to compensate for the effects of gravity
- FLOAT Return
GetInterval
GetInterval
Returns the interval at which the data is obtained from the device (in ms)
- LONG Return
Begins monitoring of the device's orientation information. Returns true if the device can provide orientation information.
- BOOL Return
Use Callback
Set true to use a callback that retrieves regular updates of the device accelerometer
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Motion.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Motion.fcsx
