Component: EBM0016 GUI (Misc)
Author Matrix
Category Misc
EBM0016_GUI component
Private non-release sub-component for the EBM0016 digital Humidity/temperature sensor.
Please click here to download the component source project: FC_Comp_Source_EBM0016_GUI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM0016_GUI.fcfx
GetData
GetData
Return a simulated register value for the given commands. Recognised commands are 0xF3 (Temperature register) and 0xF5 (Humidity Register). Note that a CRC checksum is not used in simulation.
- BYTE Command
The address of the byte to return.
SetConsoleHandle
SetConsoleHandle
Pass the parent sensor's console handle to the GUI to allow opening of the console from the 'Console' button.
- HANDLE Handle
Handle of the console
SetHumidity
SetHumidity
Sends the given Humidity to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Humidity
Relative Humidity from 0 to 100 %
SetTemperature
SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Temperature
Temperature value in Celcius,
A text label to help you identify the component on the panel.
Sub Label
Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
Number of numbered divisions shown on the thermometer scale.
I2C Data
Choose whether the I2C data is shown as decimal or hexadecimal values.
