Component: ADC (MCP356X) (Analog Input)
Author MatrixTSL
Category Analog Input
ADC (MCP356X) component
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands.
- BOOL Return
SampleADC
SampleADC
Performs a single ADC sample and returns the result as a 24-bit value
- BYTE PositiveChannel
0=CH0 - 7=CH7, 8=GND, 9=VDD, 11=REF+, 12=REF-, 13=TP, 14=TM, 15=VCM
- BYTE NegativeChannel
- LONG Return
SetGainCalibration
SetGainCalibration
Allows the device offset to be entered allowing for accurate readings.
- ULONG Gain
Default 800000 = Gain of 1X
SetOffsetCalibration
- LONG Offset
Device Configuration
Device Type
Device Address
These bits are fixed from the manufacturer and by default are 01. Used as Bits 6 and 7 of the command byte. Alternative bits must be requested from the manufacturer.
Clock Selection
Sensor Bias Current
ADC Bias Current
AMCLK Prescaler
Oversampling Ratio
ADC Gain
IRQ Mode
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Use IRQ
No: Use polling of the status register to determine when an ADC sample is complete. Yes: Use the IRQ interrupt pin to determine when an ADC sample is complete.
Simulate Comms
No: Simulation is done using panel sliders. Yes: Send SPI data via API interface and show real time data using panel sliders.
Please click here to download the component source project: FC_Comp_Source_ExternalADC_MCP356X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ExternalADC_MCP356X.fcfx
