Component: Create File ( Data)
Author MatrixTSL
Version 1.1
Category Data
Create File component
Creates a download file from a string variable.
Version information
CreateFile
CreateFile
Creates a file from the supplied filename with the supplied contents and triggers a download
- STRING Filename
Default filename assigned to the file e.g. "file.txt"
- STRING Data
Data to assign to the file
Use Defaults
Set to false to override the default settings
Raw Data
True if the data passed to the CreateFile macro needs no additional formatting
Advanced
Media Type
The MIMI type for the data - e.g. "image/jpeg" or "text/plain;charset=UTF-8"
Base64 Data
True if the data passed should be base-64 decoded before saving
Encode URI
Set true if the data needs to be encoded
Please click here to download the component source project: FC_Comp_Source_WEBEXP_CreateFile.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_CreateFile.fcsx
