Component: UART (CAL) (Misc)
Version 19.3
Category Misc
UART component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the UART peripheral. Includes simulation functionality to commmunicate via a COM port or an Injector component. Also includes timestamped logging via the console and Data Recorder trace monitoring support.
Version information
14, 2.2, 04-11-24, BR, Added pin caption to the remap port pin selection property
15, 2.2, 04-11-24, BR, Cleaned up pin caption from none remap port pin property
16, 2.2, 15-11-24, BR, Minor change to reflect changes to I2C CAL component
17, 2.3, 06-05-25, BR, Added filter to allow for automatic channel setup based on FCD and component
18, 2.3, 15-07-25, BR, Sorted the remap pin properties by port pin
19, 2.3, 11-08-25, MW, Changed fcdhelper properties to invisible as text is appearing on other projects
ControlPin
ControlPin
Allows direct control over the TX and RTS pins Also allows for reading of the state of the RX and CTS pins. Only available when the UART is uninitialised.
- BYTE Pin
0=TX, 1=RX, 2=RTS, 3=CTS
- BYTE State
Delay
Delay
Software UART Bit Delay
GetConsoleHandle
GetConsoleHandle
- HANDLE Return
GetList
GetList
Gets Named property List
- STRING Name
- STRING Return
GetValue
GetValue
Get Value of Named property
- STRING Name
- STRING Return
Init
Init
Initialize the component with the specified properties
Receive
Receive
Receive a Character
- BYTE Timeout
Period to wait for the character to be received
- INT Return
ReceiveByteArray
ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
- BYTE Data
- UINT NumBytes
Maximum number of bytes to try and receive
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveString
ReceiveString
Receives a string of bytes and returns the number of bytes received.
- STRING StringData
- UINT NumBytes
- BYTE Timeout
Send
Send
Send the Character
- UINT Char
The Character to send
SendByteArray
SendByteArray
Transmits an array of bytes via the UART peripheral
- BYTE Data
Data to transmit
- UINT NumBytes
Number of bytes to send from the array
SendNumber
SendNumber
Transmits a numeric value as an ASCII string
- LONG Number
Numeric value to send
SendString
SendString
Transmits a string of bytes via the UART peripheral
- STRING Data
Data String to transmit
SetValue
SetValue
set Value of Named property
- STRING Name
- STRING Value
TestProperty
TestProperty
A simple macro to allow us to test the value of a single property during runtime.
- BYTE Property
0=UseTX, 1=UseRX, 2=UseFlowControl
Uninit
Uninit
Un-initialize the UART and release the resources
UpdateBaud
UpdateBaud
Changes the UART Baud rate. 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
- BYTE new_baud
Component Enable
A global flag to enable or disable the UART component from producing code. Useful for generating components with multiple communications options.
Filter
If set compares to the info section in the FCD to allow for auto connection to the correct channel
Transmit
Use TX
Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
Use TX Buffer
Decides what to do if there is more then one byte to send or if the UART is already transmitting data. No: When additional data is transmitted the processor will sit and wait for the data to be sent. Yes: The data to be sent will be placed into a buffer allowing the processor to continue with other things, the buffer will automatically empty itself using a UART TX interrupt.
Receive
Use RX
Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
Use RX Buffer
Decides what to do when data is received. No: The UART must be regularily polled or the user must enable their own receive interrupt to catch data as it comes in. Yes: The received data will be placed into a buffer using a UART RX interrupt.
Flow Control
Use Flow Control
Options
Baud Options
Data Bits
Number of data bits
Return data width from Receive macro. 8-bit data mode always returns a byte ranging from 0-255, 255 could mean a timeout or could be a valid data. 16-bit data mode rereturns 0-255 for valid data, 256 for a timeout, return data must be stored into an INT or UINT variable.
Echo
Automatically echoes back any received data when enabled by re-transmitting the received byte.
Interrupt
Automatic receive interrupt mode enable or disable. Used on components such as the GSM or GPS where data can come in at any time. Software channel is disabled when interrupt is enabled, for interrupt with a software channel use an I/O edge triggered interrupt.
Console Format
Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
Data Source
Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
Please click here to download the component source project: FC_Comp_Source_UART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART.fcfx
