Component: LIN Master (Comms)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category Comms
LIN Master component
Low level routines for controlling a LIN master (1.3 & 2.0) interface.
Please click here to download the component source project: FC_Comp_Source_LinMaster.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LinMaster.fcfx
GetState
GetState
Returns the current state
Initialise the component
PowerDown
PowerDown
Power Down the device
ReadData
ReadData
Returns a data byte indexed by Idx
- BYTE Idx
ReadDataCount
ReadDataCount
Returns the data count size
SendMessage
SendMessage
Sends message with specified identifier and awaits a reply from a slave. Returns 0 to indicate a successful transaction. Returns 3 to indicate a timeout. Returns 6 to indicate a bad CRC.
- BYTE Identifier
- BYTE ResponseCount
- BYTE ChecksumType
0=Classic, 1=Enhanced
SendMessageWithData
SendMessageWithData
Sends a message with data of length DataCount. See SetData
- BYTE Identifier
- BYTE DataCount
- BYTE Checksum
SetData
SetData
Sets the data bytes to be sent
- BYTE Data1
- BYTE Data2
- BYTE Data3
- BYTE Data4
- BYTE Data5
- BYTE Data6
- BYTE Data7
- BYTE Data8
WakeUp
WakeUp
Wake Up the device
debug
debug
- BYTE idx
LIN bus data rate in bits per second
Label shown on the comms flasher component.
TX
LIN Transmit Pin
RX
LIN Receive Pin
CS
LIN bus chip select pin
WAKE
LIN bus Wake up pin
