Component: CAN (CAL) (Misc)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 2.4
Category Misc
CAN component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. Low level routines for controling the internal CAN peripheral.
Please click here to download the component source project: FC_Comp_Source_CAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CAN.fcfx
CheckRx
CheckRx
Checks to see if any messages are available for 'Buffer' specified
- BYTE Buffer
Send buffer: 0 to 1
GetList
GetList
Get the Filter List of the Named Property
- STRING Name
- STRING Return
GetRxData
GetRxData
Returns the data byte at index from the buffer specified
- BYTE buffer
The index of the required buffer
- BYTE index
The index of the required data byte in the buffer
GetRxDataCount
GetRxDataCount
Returns the number of valid data bytes in the buffer
- BYTE buffer
GetRxIdent
GetRxIdent
Generic function to get the received message Identifier.
- BYTE buffer
- ULONG Return
GetValue
GetValue
Get the Value of the Named property
- STRING Name
- STRING Return
Init
Init
Must be called at least once and after every Uninit call to enable the CAN instance
InitRXConfig
InitRXConfig
Initialization setting for RX Buffer Config
- BYTE Buffer
Buffer Number (0 or 1)
- BYTE Value
Config data byte
InitRXFilter
InitRXFilter
Initialization setting for RX Filter
- BYTE Filter
- ULONG Value
InitRXMask
InitRXMask
Initialization setting for RX Mask
- BYTE Mask
Mask Number (0 or 1)
- ULONG Value
InitTXBuffer
InitTXBuffer
Initialization settings for TX Buffers
- BYTE Buffer
TX Buffer ID = 0,1 or 2
- ULONG ID
CAN Address
- BYTE Length
Number of bytes to send
- STRING Data
Data Array (of Length bytes)
SendBuffer
SendBuffer
Sends the contents of the buffer previously filled with Set_TX_... calls
- BYTE Buffer
Send buffer: 0 to,2
SetRxFilter
SetRxFilter
Generic function to set Identifier. CAN registers will be configured depending upon Std/Ext mode setting.
- BYTE filter
- ULONG id
SetRxFilterExd
SetRxFilterExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
- BYTE Filter
Send filter: 0 to 3
- BYTE ID3
The high byte (bits 24-31) of the ID
- BYTE ID2
The mid-high byte (bits 16-23) of the ID
- BYTE ID1
The mid-low byte (bits 8-15) of the ID
- BYTE ID0
The low byte (bits 0-7) of the ID
SetRxFilterStd
SetRxFilterStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
- BYTE Filter
Filter number
- BYTE Hi
The high byte (bits 8-15) of the ID
- BYTE Lo
SetRxMask
SetRxMask
- BYTE mask
- ULONG id
SetRxMaskExd
SetRxMaskExd
- BYTE Mask
Mask 0 or 1
- BYTE ID3
- BYTE ID2
- BYTE ID1
- BYTE ID0
SetRxMaskStd
SetRxMaskStd
- BYTE Mask
Mask number
- BYTE Hi
- BYTE Lo
SetTxData
SetTxData
Sets the CAN transmit data for the buffer specified (0, 1 or 2). The count parameter Data_Cnt indicates the number of valid data bytes. D0 to D7 are the payload data bytes to be loaded into the transmit buffer.
- BYTE Buffer
Send buffer: 0 to,2
- BYTE Data_Cnt
The number of bytes of data to add, 0 to 8
- BYTE D0
Data byte 0 to add
- BYTE D1
Data byte 1 to add
- BYTE D2
Data byte 2 to add
- BYTE D3
Data byte 3 to add
- BYTE D4
Data byte 4 to add
- BYTE D5
Data byte 5 to add
- BYTE D6
Data byte 6 to add
- BYTE D7
Data byte 7 to add
SetTxIdent
SetTxIdent
- BYTE buffer
- ULONG id
SetTxIdentExd
SetTxIdentExd
Sets the optional 32-bit ID to send along with the standard ID and data in the next CAN message
- BYTE Buffer
Send buffer: 0 to,2
- BYTE ID3
- BYTE ID2
- BYTE ID1
- BYTE ID0
SetTxIdentStd
SetTxIdentStd
Sets the ID to send along with the data in the next CAN message
- BYTE Buffer
Send buffer: 0 to,2
- BYTE Hi
- BYTE Lo
SetValue
SetValue
Set the Value of the Named property
- STRING Name
- STRING Value
Uninit
Uninit
Uninitialises the CAN, freeing its connections for general use
Selects the CAN channel to be used
TX Pin
RX Pin
TX Remap
RX Remap
Bus Rate
selects the Bus Rate (KHz)
Sample Point
selects the Sample Point for bit reading
SJW
Synchronization Jump Width adjusts the bit clock by 1 to 4 TQ periods
Fosc
BRGCON1
BRGCON2
BRGCON3
ID Type
selects the CAN ID type
TX Buffer 0
Message ID
CAN Message ID for Transmit Buffer 0
Length
Number of valid data bytes in the message
D0
Data byte 0
D1
Data byte 1
D2
Data byte 2
D3
Data byte 3
D4
Data byte 4
D5
Data byte 5
D6
Data byte 6
D7
Data byte 7
TX Buffer 1
Message ID
CAN Message ID for Transmit Buffer 1
Length
D0
Data byte 0
D1
Data byte 1
D2
Data byte 2
D3
Data byte 3
D4
Data byte 4
D5
Data byte 5
D6
Data byte 6
D7
Data byte 7
TX Buffer 2
Message ID
CAN Message ID for Transmit Buffer 2
Length
D0
Data byte 0
D1
Data byte 1
D2
Data byte 2
D3
Data byte 3
D4
Data byte 4
D5
Data byte 5
D6
Data byte 6
D7
Data byte 7
RX Buffer 0
Settings
Filter setting for Receive Buffer 0
Mask
Value for Receive Mask 0
Filter 0
Value for Filter 0
Filter 1
Value for Filter 1
RX Buffer 1
Settings
Filter setting for Receive Buffer 1
Mask
Value for Receive Mask 1
Filter 2
Value for Filter 2
Filter 3
Value for Filter 3
Filter 4
Value for Filter 4
Filter 5
Value for Filter 5
