Component: LED Mono (LED)
Version 19.0
Category LED
LED Mono component
LED indicator for both embedded and App Developer.
Version information
18, 1.0, 01-07-25, MW,User Lable Text not changed with Handle. Added Rename event
19, 1.0, 27-08-25, MW, improved functionality, added Hidden option for handle & bug fixes
Here is an example Flowcode program to read the value of a switch and change the state of LED accordingly. LED Example
LED Resistor Calculator Tool
SetState
SetState
Sets the state of the LED, accounting for the polarity.
- BOOL State
1=On, 0=Off
TurnOff
TurnOff
TurnOn
TurnOn
Function
Simulation Only
LED Settings
Connection
Component Label
Component label position
Label Colour
Polarity
Show Connection Label
If enabled, the pin designation will be shown, e.g. B0.
Show Pin Value
Pin status of VCC or GND will be shown when enabled and simualtion is running.
Pin label position
Shape
Colour
Style
Please click here to download the component source project: FC_Comp_Source_LED_Mono_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Mono_2dgi.fcfx
