Component: Infrared Array AMG88xx (Light)
Category Light
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Please click here to download the component source project: FC_Comp_Source_AMG88.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AMG88.fcfx
ClearInterrupt
ClearInterrupt
Clear any triggered interrupts
Sets up the I2C interface and initialises the sensor.
ReadPixel
ReadPixel
Reads the temperature of a single pixel value from the last SamplePixels call.
- BYTE Index
Pixel to read. Range: 0 - 63
- FLOAT Return
ReadThermistor
ReadThermistor
Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value
- FLOAT Return
SamplePixels
SamplePixels
Reads Infrared sensor values
SetInterrupt
SetInterrupt
Allows the interrupt pin to be enabled or disabled.
- BOOL Mode
0 = Disabled / 1 = Enabled
SetInterruptLevels
SetInterruptLevels
Set the interrupt levels. Interrupt when going above High or interrupt when going below Low.
- FLOAT High
Range: -1023 to 1023
- FLOAT Low
- FLOAT Hysteresis
Range: -1023 to 1023 ( Recommend 0.95 * High )
SetInterruptMode
SetInterruptMode
Set the interrupt to either absolute value or difference mode
- BOOL Mode
0 = Difference / 1 = Absolute
SetMovingAverageMode
Set the moving average mode on or off.
- BOOL Mode
0 = Off, 1 = On
Address
Channel selection
SDA
SCL
Baud Select
Baud rate to be used
Stop Delay
API
