Component: GLCD Graph Creator XY (Graphical Library)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category Graphical Library
GLCD Graph Creator XY component
A component to simplify the process of drawing XY graphs and charts using a graphical LCD.
AddPoint
AddPoint
Adds a new data point to the graph.
- INT X
X Data Value to plot
- INT Y
Y Data Value to plot
- BYTE Index
Plot Index: Range 0-7
Initialises the graph object on the GLCD to the specified dimensions.
Display Properties
LinkTo
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
X Coord
X coordinate for the top left of the graph container rectangle
Y Coord
Y coordinate for the top left of the graph container rectangle
Width
Horizontal size of the graph in pixels
Height
Vertical size of the graph in pixels
Graph Properties
Number Of Plots
Determines the number of plots that can be displayed simultaneously on the graph. Monochrome displays can only support a single plot.
Number Of Points
Number of data points the graph can store, multiplied by the number of plots.
Graph Style
Controls the graph draw style. Point - Draws a single point Line - Draws a line from the last point to the new point
Min X Value
Value to represent the left X axis on the graph
Max X Value
Value to represent the right X axis on the graph
Min Y Value
Value to represent the bottom Y axis on the graph
Max Y Value
Value to represent the top Y axis on the graph
Show Border
Decides if a border for the graph is generated
Show Grid
Decides if a X or Y grid is shown for the graph
Theme
Background Colour
Determines the graph background colour.
Plot 0 Colour
Determines the graph plot colour.
Please click here to download the component source project: FC_Comp_Source_Lib_GLCD_GraphXY.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_GLCD_GraphXY.fcfx
