Component: MIAC Bluetooth (MIAC: Addon Modules)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author
Category MIAC: Addon Modules
MIAC Bluetooth component
Bluetooth Addon for MIAC System
FREE
BluetoothCount
Returns the number of bytes waiting to be read from the receive buffer
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
BluetoothSendString
send string to Bluetooth module
- STRING Str
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
BluetoothChangeBaud
Changes the Bluetooth communication baud rate: 1 = 1200, 2 = 2400, 3 = 4800, 4 = 9600, 5 =19200, 6 =38400, 7 = 57600, 8 = 115200 (Applies to HC-06 module only)
- BYTE Baud
New baud rate. 1=1200, 4=9600, 6=38400, 8=115200
BluetoothSetPin
Changes the pincode to a new value. The passcode is four digits, e.g. 1234 (Applies to HC-06 module only)
- STRING Pincode
New four digit pincode
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
MIAC_Module_PushData
- BYTE Data
BluetoothSetName
Changes the module Name to a new value. (Applies to HC-06 module only)
- STRING Name
New four digit passcode
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
BluetoothRead
Read one character from the Bluetooth module receive buffer. Returns 0 if nothing in the receive buffer
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
BluetoothInitialize
Initializes the Bluetooth module (enables buffered receive mode)
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
BluetoothSend
Sends a character to the Bluetooth module
- BYTE Character
Character (Byte) to send
Initialize
Forces a software reset on the module and enables buffered receive.
DigitalInput
Read the value of a terminal
- BYTE Terminal
Module Type
Module Address
Simulations
