Component: Slider control (Advanced Shapes)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.1
Category Advanced Shapes
Slider control component
A simple graphical interface for a vertical meter or slider control. This can be used within custom components to give them a way to display an analogue value, or to allow setting a value by clicking and dragging with the mouse.
Please click here to download the component source project: FC_Comp_Source_slider.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_slider.fcfx
Simple example showing how to use the simulation slider component as a meter display for use in monitoring type applications. Meters
GetValue
GetValue
Gets the current value of the slider. This will be within the range set by the SetRange macro.
- FLOAT Return
SetInteractive
SetInteractive
Set whether the mouse can be used to change the slider value.
- BOOL Enable
Set true to allow clicks to set scale
SetRange
SetRange
Set the minimum and maximum values that can be shown on the slider.
- INT Min
Min (start) value
- INT Max
Maximum (end) value
SetValue
SetValue
Set the current value of the slider. This will override any value set by using the mouse.
- FLOAT Value
The value to set.
ShowScale
ShowScale
Set whether graduated marking are shown along the length of the slider.
- BOOL Show
True to show scale, else false
