Component: Temperature (TMP117) (Environmental)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Environmental
Temperature (TMP117) component
The TMP117 provides high accuracy temperature monitoring via a digital I2C interface.
A basic example which moves an object on the panel. When the object is in range of the sensor the sensor output goes high, otherwise the sensor output goes low. PhotoTransistorDemo
Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified.
- BOOL Return
ReadRegister
ReadRegister
- BYTE Address
ReadTemperature
ReadTemperature
Reads the temperature as a floating point value in Celcius.
- FLOAT Return
ReadTemperatureF
ReadTemperatureF
Reads the temperature as a floating point value in Fahrenheit
- FLOAT Return
SetMode
SetMode
Sets the mode of the sensor and therefore the amount of power consumed by the sensor.
- BYTE Mode
0=Shutdown, 3=Triggered, 7=Continuous
SetTemperatureOffset
Allows an offset to be written to offset the output temperature
- FLOAT Offset
Temperature offset in degrees C
WriteRegister
WriteRegister
- BYTE Address
- UINT Value
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Settings
Address A0
Sets the I2C device address based on the state of the device AD0 pin
Default Mode
Sets the default mode of the sensor on initialise. Can be overridden using the SetMode macro.
Standby Time
Sets the amount of time to wait between samples to save power.
Averaging Count
Sets the number of samples used for each averaging period. Can be overridden using the SetAveragingCount macro.
Alert Polarity
Alert Type
Simulate Comms
API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_Temperature_TMP117.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_TMP117.fcfx
