Component: Servo Motor (BL0162) (E-blocks 2)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category E-blocks 2
Servo Motor component
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board. Provides up to eight individually addressable connections for standard DC servo motors to be connected.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Servo_BL0162.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Servo_BL0162.fcfx
Example showing how to control three servos using AutoMoveToPosion, MoveTopposition & SetPosition component macros.
Controlling Servos Example.fcfx
Example using BL0162 Servo controller for BL0055 Arduino Shield
Samples the Port D8-D13 (portB) switches and moves the servo motors based on the input states.
D8 increments motor 0, D9 decrements motor on channel 0.
D10 increments motor 1, D11 decrements motor on channel 1.
D12 increments motor 3, D13 decrements motor on channel 2.
Connections:
Servo Board Port D0-D2.
Switch Board Port D8 - D13
LCD A0 to A5 (PortC)
BL0162 Servos Example for BL0055
AutoMoveToPosition
AutoMoveToPosition
Automatically moves towards the new position with a fixed rate of 100 steps per second.
- BYTE Channel
The channel to set the position for. First channel is zero.
- BYTE Position
Position to move to.
DisableServo
DisableServo
Disables a servo channel effectivly disabling the motor.
- BYTE Channel
EnableServo
EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE Channel
Sets up the servo motor interrupts
IsAutoMoving
IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
MoveToPosition
MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
- BYTE Position
Target position to move towards.
SetAutoMoveSpeed
SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is 1.
- BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
SetPosition
SetPosition
Moves directly to the specified position with no interpolation.
- BYTE Channel
- BYTE Position
SetTrim
SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE Channel
- BYTE Trim
0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us
Channels (1 - 8)
Set the number of servo's that you need to control. Value from 1 to 8.
Channel 0
Pin on which to output PWM for the servo motor.
Channel 1
Channel 2
Channel 3
Channel 4
Channel 5
Channel 6
Channel 7
Pulse Width
Minimum (us)
Shortest pulse width that will be used.
Maximum (us)
Longest pulse width used for the PWM signals.
Trim
Trim 0
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Trim 1
Trim 2
Trim 3
Trim 4
Trim 5
Trim 6
Trim 7
Show Servo Interface
Servo Object 0
Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
Servo Object 1
Servo Object 2
Servo Object 3
Servo Object 4
Servo Object 5
Servo Object 6
Servo Object 7
