Component: Temp / Humidity (HTS221) (Environmental)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Environmental
Temp / Humidity (HTS221) component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
Please click here to download the component source project: FC_Comp_Source_Humidity_HTS221.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_HTS221.fcfx
ControlHeater
ControlHeater
Controls the in-built heater element to speed up sensor recovery time in case of condensation. Humidity and temperature cannot be read while Heater is active.
- BOOL Active
0 = Off (Sensor Reading Available) / 1 = On (Sensor Reading Disabled)
DataAvailable
DataAvailable
Checks to see if new sensor data is available. Returns 0 if no new data is available. Returns 1 if new Temperature data is available. Returns 2 if new Humidity data is available. Returns 3 if new Temp and Humidity data is available.
Configures the I2C peripheral ready for communications.
ReadHumidityInt
ReadHumidityInt
Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100
ReadHumidityReal
ReadHumidityReal
Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0.
- FLOAT Return
ReadRegister
ReadRegister
Reads an 8-bit value from one of the registers onboard the sensor IC.
- BYTE Address
ReadTemperatureInt
ReadTemperatureInt
Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120.
- INT Return
ReadTemperatureReal
ReadTemperatureReal
Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0.
- FLOAT Return
WriteRegister
WriteRegister
Writes a value to a register on the sensor IC.
- BYTE Address
- BYTE Data
Sensor Properties
Data Rate
I2C Properties
Address
Channel selection
SDA
SCL
Stop Delay
Baud Select
Baud rate to be used
Sim Type
