Component: Switch Push Button (Switch)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 21.0
Category Switch
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
15, 15.0, 30-07-24, MW, Fixed a bug to make sure switch starts in the off position
17, 17.0, 16-04-25, MW, Fixed a bug that made boundary height too large
17, 17.0, 16-04-25, MW, Fixed a bug where Pin x and  y lables remained visisble when supposed to be hidden
17, 17.0, 16-04-25, MW, Fixed a bug when sim stopped Switch changed from on to off, but pin remained at VCC
18, 18.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size
18, 18.0, 01-05-25, MW, Changed labels so don't interact and change switch state
19, 19.0, 01-05-25, BR, Added option to hide label
19, 19.0, 01-05-25, BR, Fixed SameAsHandle label to update on rename event
20, 0.0, 14-05-25, MW, Changed Switch properties, so it does not grey out
21, 21.0, 10-03-26, ST, Updated for v11.0.1 mouse event change
Here is an example Flowcode program to read the value of a switch. Switch
(5V / 11K) * 10K = 4.54545V
Note: if you want to use switch functions e.g. Active Low or debounce ,you must use the ReadState function and not use just an input.
ReadState
ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
SetState
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilHigh
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
WaitUntilLow
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Function
Simulation Only
Switch Settings
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = Set, Released = Clear 'Active Low' -> Pressed = Clear, Released = Set
Debounce
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Latching
Determines if the simulated switch maintains its state or revers back to the default state when not clicked.
Component Label
Component label position
Label Colour
Show Connection Label
Show Pin Value
Pin label position
Style
Type
On Label
Off Label
Please click here to download the component source project: FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
