Component: API (Interface Board) (API Slave Devices)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Category API Slave Devices
API (Interface Board) component
Connects to an Interface Board running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Please click here to download the component source project: FC_Comp_Source_Interface_Board_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Interface_Board_Comp.fcfx
A board designed to allow PC access to embedded style electronic signals at 3V3 or 5V.
Includes: ADC / DAC / I2C / IO / Servo / SPI / UART
USB Firmware allows control via a USB connection. Works with a Windows PC but should also work with other USB master based devices.
WIFI Firmware allows control via a WIFI network connection. Works with any networked device including devices via the internet. WIFI connection requires the use of the UART peripheral and so this is not available for Slave functionality when using the WIFI firmware.
Board supplied with firmware as requested. Firmware can be changed using a PICkit 3 or PICkit 4 device or similar Microchip programmer.
To setup the WIFI to work with your own network you first need to power up the board using a USB connection or by applying a 5V power supply between the 5V and GND pins. Next connect to the WIFI network hosted by the board with the network name InterfaceBoard using password all in lowercase as the Password. Visit the website at page 192.168.4.1 and then enter your WIFI network details into the form provided. On clicking ok the board will store the details in none volatile memory and attempt to connect to your network and establish a local IP address. If all goes ok here then the Interface Board network should dissappear.
Refer to your router configuration page to see the IP address of the device.
If the WIFI network is not available then the board will revert back to it's setup mode allowing the network to be changed. Once network connection is available again the board will automatically reconnect.
The latest updates can be found on github
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
Simple Interface Board Demo
ADCSample10
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
- BYTE ADCChannel
Range: 0-5
ADCSample8
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
- BYTE ADCChannel
Range: 0-5
I2CInitialise
I2CInitialise
- BYTE Channel
- BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
I2CReceive
I2CReceive
- BYTE Channel
- BOOL Last
I2CRestart
I2CRestart
- BYTE Channel
I2CSend
I2CSend
- BYTE Channel
- BYTE DataOut
- BOOL Return
I2CStart
I2CStart
- BYTE Channel
I2CStop
I2CStop
- BYTE Channel
I2CTransInit
I2CTransInit
- BYTE Channel
- BYTE DeviceAddress
7-bit Device Address
- BYTE Baud
I2CTransReceive
I2CTransReceive
- BYTE Channel
- BYTE Data
Data variable to receive into
- UINT Count
Number of bytes to receive
I2CTransSend
I2CTransSend
- BYTE Channel
- BYTE Data
Data to send
- UINT Count
IOGetInputPin
IOGetInputPin
- BYTE Pin
Range: 0-17
- BOOL Return
IOSetOutputPin
IOSetOutputPin
- BYTE Pin
Range: 0-17
- BOOL State
Range: 0-1
PWMDisable
PWMDisable
Disable a PWM output
- BYTE Channel
Range: 0-1
PWMEnable
PWMEnable
Enable a PWM output
- BYTE Channel
Range: 0-1
PWMSetDuty8
PWMSetDuty8
- BYTE Channel
Range: 0-1
- BYTE Duty
Range: 0-255
PWMSetPrescaler
PWMSetPrescaler
- BYTE Prescaler
SPIInitialise
SPIInitialise
- BYTE Channel
SPIPrescaler
SPIPrescaler
- BYTE Channel
- BYTE Prescaler
Range: 0-2
SPITransfer
SPITransfer
- BYTE Channel
- BYTE DataOut
SPITransferTrans
SPITransferTrans
- BYTE Channel
- UINT Count
- BYTE DataOut
Outgoing data
- BYTE DataIn
Incoming data
ServoDisable
ServoDisable
Disable a Servo output
- BYTE Channel
Range: 0-5
ServoEnable
ServoEnable
Enable a Servo output
- BYTE Channel
Range: 0-5
ServoSetPosition8
ServoSetPosition8
Sets the position as an 8-bit value
- BYTE Channel
Range: 0-1
- BYTE Position
Range: 0-255
UARTBaud
UARTBaud
- BYTE Channel
- BYTE Rate
UARTCheckRX
UARTCheckRX
- BYTE Channel
UARTInitialise
UARTInitialise
- BYTE Channel
UARTReceive
UARTReceive
- BYTE Channel
UARTSend
UARTSend
- BYTE Channel
- BYTE Data
WIFIGetIP
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
- STRING Return
WIFIIsConnected
WIFIIsConnected
Checks to see if the WIFI is active and connected
- BOOL Return
WIFISetSSID
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
- STRING SSID
Name of the network you wish to connect to
- STRING Password
Connection Type
Connection Properties
Auto Detect Port
Allows the component to auto detect the interface board COM port. Requires the latest Flowcode serial comms DLL to function correctly.
Scan Results
Lists the IP addresses found during the last scan, Overwrites the selected WIFI IP property when changed.
Scan Start
Address to set the scan start point. For example 10 might generate 192.168.1.10 depending on your IP setting. Scan then proceeds from there so for example 11, 12, 13, ..., 254, 255. Default 0
End Scan
Decides how the scan is terminated
API Peripherals
Digital IO
Analog Input
Analog Output
PWM Output
I2C Bus
SPI Bus
UART
SERVO
Logging
Console Log
Create an automatic console log of the commands sent to the device
Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
Show Raw
Shows the raw data stream via a console window
