Component: Switch Slide (Switch)
Version 20.2
Category Switch
Switch Slide component
A simple digital slide switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
10, 10.0, 23-09-24, MW, Fixed a bug to  make sure switch starts in the off position
10, 10.0, 23-09-24, MW, Added option for simulation only
10, 10.0, 23-09-24, MW, Fixed a bug preventing custom lable posistion from updating on the fly
11, 11.0, 23-09-24, MW, Fixed connection lable so show correct polariy within array
12, 12.0, 15-04-25, MW, Modified switch to show correct value for off when stating and stopping simulation
12, 12.0, 16-04-25, MW, Fixed a bug where Pin x and  y lables remained visisble when supposed to be hidden
13, 18.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size
13, 18.0, 01-05-25, MW, Changed labels so don't interact and change switch state
13, 18.0, 01-05-25, MW, Corrected pin label properties
14, 19.0, 01-05-25, BR, Added option to hide label
14, 19.0, 01-05-25, BR, Fixed SameAsHandle label to update on rename event
15, 19.1, 14-05-25, MW, Corrected switch properties
16, 20.0, 10-03-26, ST, Updated for v11.0.1 mouse event change
Here is an example Flowcode program to read the value of a switch. Switch Slide Example
(5V / 11K) * 10K = 4.54545V
ReadState
ReadState
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
SetState
SetState
Sets the switch to be on or off.
- BOOL State
The new state of the switch (true=on, false=off)
WaitUntilHigh
WaitUntilHigh
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity
WaitUntilLow
WaitUntilLow
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity
Function
Simulation Only
Switch Settings
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = Set, Released = Clear 'Active Low' -> Pressed = Clear, Released = Set
Debounce
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Latching
Determines if the simulated switch maintains its state or revers back to the default state when not clicked.
Component Label
Component label position
Label Colour
Show Connection Label
Show Pin Value
Pin label position
Style
Type
On Label
Off Label
Please click here to download the component source project: FC_Comp_Source_Switch_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Slide_2dgi.fcfx
