Component: Switch Array (Push) (Switches)
Author MatrixTSL
Version 14.0
Category Switches
Switch Array (Push) component
An array of up to eight push switches. In embedded mode each switch is connected to a single pin of the specified port.
Version information
12, 11.0, 26-06-24, MW, Removed [2D] from the component name
13, 13.0, 16-04-25, MW, Corrected bug when sim stopped Switch changed from on to off, but pin remained at VCC
13, 13.0, 16-04-25, MW, Fixed bug so individual customisation now works
 13, 13.0, 16-04-25, MW, Created a new component icon
14, 14.0, 10-03-26, ST, Type, Label On/Off and Colour now transferred correctly
Here is an example Flowcode program to read the values of a switch array. Switch Array
(5V / 11K) * 10K = 4.54545V
ReadAll
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
ReadState
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
WaitUntilLow
WaitUntilLow
- BYTE Index
Count
The number of LEDs in the array from 1 to 8.
Function
Simulation Only
Switch Settings
Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Port
Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Component Label
Allows you to add your own label to each switch. If Same as Handle is selected then all custom text will be erased.
Switch layout
Distance between switches
Set distance betwwn each switch. Default = 55
Style
Type
On Label
Off Label
Label Colour
Show Connection Label
Show Pin Value
Please click here to download the component source project: FC_Comp_Source_Switch_Array_Push_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Array_Push_2dgi.fcfx
