Component: EtherCAT Slave (EasyCAT) (Comms: IoT/Cloud)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Comms: IoT/Cloud
EtherCAT Slave (EasyCAT) component
Provides support for the EtherCAT Slave industrial protocol using an EasyCAT Arduino shield. The shield can be driven from a Flowcode compatible Arduino type board or can be driven using an Arduino using the SCADA Slave firmware to drive EtherCAT from the Flowcode simulation runtime. Compatible with the EasyCAT Easy Configurator tool.
Please click here to download the component source project: FC_Comp_Source_EasyCat.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EasyCat.fcfx
GetByte
GetByte
Read a 8-bit value from the Out receive buffer
- BYTE Index
Data Index
GetFloat
GetFloat
Read a 32-bit floating point value from the Out receive buffer
- BYTE Index
Data Index
- FLOAT Return
GetInt
GetInt
Read a 16-bit value from the Out receive buffer
- BYTE Index
Data Index
GetLong
GetLong
Read a 32-bit value from the Out receive buffer
- BYTE Index
Data Index
- ULONG Return
Starts up the SPI connection to the EasyCAT board and configures the board. Returns 1 for a sucessful initialise.
- BOOL Return
MainTask
MainTask
Must be called as part of the application main program loop.
SetByte
SetByte
Write an 8-bit value to the In receive buffer
- BYTE Index
Data Index
- BYTE Data
SetFloat
SetFloat
Write a 32-bit floating point value to the In receive buffer
- BYTE Index
Data Index
- FLOAT Data
SetInt
SetInt
Write a 16-bit value to the In receive buffer
- BYTE Index
Data Index
- UINT Data
SetLong
SetLong
Write a 32-bit value to the In receive buffer
- BYTE Index
Data Index
- ULONG Data
Synchronisation Mode
ASYNC = free running i.e. no synchronization between master and slave (default) DC_SYNC = interrupt is generated from the distributed clock unit SM_SYNC = interrupt is generated from the syncronisation manager
Header File
Used to load a header file from Easy CAT Configurator tool to describe the units inputs and outputs
Data Rx
Total Byte Num Out
Total number of bytes to come out from the EtherCAT master
Data Tx
Total Byte Num In
Total bytes to come in from the EtherCAT master
SPI Properties
SPI Channel selector
MOSI
MISO
CLK
CS / SS
Prescale
Prescale option selector
Simulation Comms
