Component: Magnetometer (BMM150) (Environmental)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Author MatrixTSL
Category Environmental
Magnetometer (BMM150) component
A low-power, low-noise 3-axis digital geomagnetic sensor that perfectly matches the requirements of compass applications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_BMM150.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_BMM150.fcfx
Startup communications to the sensor module. Puts the device into normal operating and preset modes. Returns 1 if module found and communicating.
ReadRegister
ReadRegister
A simple example showing a generic way to read a register using I2C.
- BYTE Address
ReadSample
ReadSample
Collect a sample fromt he last SampleMag operation
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
SampleMagData
SampleMagData
Samples the magnetometer and processes the data ready to be read out using the read sample macro.
- BOOL ApplyTrim
0=ReadRawValues, 1=ApplyCalibrationTrim
SetOperatingMode
SetOperatingMode
Select the operating mode and power level used by the device
- BYTE Mode
0=Normal, 1=Forced, 3=Sleep, 4=Suspend
SetPresetMode
SetPresetMode
Controls the device sample rate and accuracy
- BYTE Mode
0=LowPower, 1=Normal, 2=HighAccuracy, 3=Enhanced
WriteRegister
WriteRegister
A simple example showing a generic way to write a register using I2C.
- BYTE Address
- BYTE Data
Component Properties
Device Address
Preset
Sets the default preset for the module. Can be overridden by calling the SetPresetMode component macro.
I2C Properties
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Options
Stop Delay
Baud Select
Baud rate to be used
Simulate Comms
