Component: Analogue (BL0189) (E-blocks 2)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category E-blocks 2
Analogue component
A component to drive the BL0189 Analogue board including Light Sensor, Twin Potentiometers and Thermistor.
GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT Return
GetRealTemperature
GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT Return
IO_ReadAnalogAsByte
IO_ReadAnalogAsByte
Reads one of the analogue components as an byte value
- BYTE Channel
0 = Light Sensor, 1 = Pot1, 2 = Pot2, 3 = Thermistor
IO_ReadAnalogAsInt
IO_ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
- INT Return
Analog Connections
Light Sensor
Pot1
Pot2
Thermistor
ADC Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Analog Scope Traces
Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Analogue_BL0189.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Analogue_BL0189.fcfx
