Component: LED Matrix Dummy (HT16K33) (Outputs: LEDs)
| Author | Matrix Ltd |
| Version | 1.2 |
| Category | Outputs: LEDs |
LED Matrix Dummy component
LED Matrix component designed to work using a HT16K33 LED driver IC. Can drive up to 16 x 8 (128) LEDs. Includes support for 8x16 Backpack, 16x8 Featherwing, 8x8 Backpack and Custom.
Please click here to download the component source project: FC_Comp_Source_LED_Matrix_HT16K33_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Matrix_HT16K33_Dummy.fcfx
ClearLEDs
| ClearLEDs | |
| Sets all of the LEDs in the matrix to the off state. | |
DisplayString
| Configures the I2C peripheral and sets up the HT16K33 IC ready to drive the LEDs. | |
SetBrightness
| SetBrightness | |
| Configures the brightness of the LEDs by varying the On portion of the duty. | |
| Brightness | |
| Range: 0-15 - 0 = Min Brightness, 15 = Full Brightness | |
ShiftColumns
| ShiftColumns | |
| Shifts the columns one place left or right. Used for things like displaying scrolling text. | |
| Direction | |
| 0 = Shift Left, 1 = Shift Right | |
WriteColumn
| WriteColumn | |
| Allows a single column of 8 LEDs to be controlled in a single action. | |
| Column | |
| Range: 0-15 | |
| Data | |
| Data to display on the column of LEDs | |
WriteCommand
| WriteCommand | |
| Writes a command. | |
| Command | |
WriteLED
WriteLEDXY
WriteRegister
| WriteRegister | |
| Writes a value to a register. | |
| Address | |
| Value | |
