Component: FRAM MB85RC (EEPROM)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category EEPROM
FRAM MB85RC component
I2C Ferroelectric Random Access Memory (FRAM) component for Fujitsu MB85RC and Cypress FM24/CY15B series devices. Supports 4K to 1M devices. Based on FRAM_MB85RC_I2C Arduino library.
Here's a simple file to test the functionality of the FRAM device.
FRAM Test
DisableWriteProtect
DisableWriteProtect
Disables write protection on the FRAM device. Returns error code: 0=success
EnableWriteProtect
EnableWriteProtect
Enables write protection on the FRAM device. Returns error code: 0=success
EraseDevice
EraseDevice
Erases the entire FRAM device by writing zeros to all memory locations. Returns error code: 0=success, 1-4=error
Initializes the I2C interface and prepares the FRAM device for operation. Returns error code: 0=success, 1-4=error
Read
Read
Reads a single byte from the specified FRAM address. Returns the byte value read, or 0xFF on error.
- ULONG Address
Memory address to read from
ReadFloat
ReadFloat
Reads a 32-bit floating point value (FLOAT) from the specified FRAM address. Returns the float value read, or 0.0 on error.
- ULONG Address
- FLOAT Return
ReadInt
ReadInt
Reads a 16-bit signed integer (INT) from the specified FRAM address. Returns the integer value read, or 0 on error.
- ULONG Address
- INT Return
ReadLong
ReadLong
Reads a 32-bit signed integer (LONG) from the specified FRAM address. Returns the long value read, or 0 on error.
- ULONG Address
- LONG Return
ReadPage
ReadPage
Reads multiple bytes starting from the specified address. Returns number of bytes read, or 0 on error.
- ULONG Address
Starting memory address
- BYTE Data
Buffer to store read data
- UINT Count
Number of bytes to read
Write
Write
Writes a single byte to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG Address
Memory address to write to
- BYTE Data
Byte value to write
WriteFloat
WriteFloat
Writes a 32-bit floating point value (FLOAT) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG Address
- FLOAT Data
Float value to write
WriteInt
WriteInt
Writes a 16-bit signed integer (INT) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG Address
- INT Data
Integer value to write
WriteLong
WriteLong
Writes a 32-bit signed integer (LONG) to the specified FRAM address. Returns error code: 0=success, 1-4=error
- ULONG Address
- LONG Data
Long value to write
WritePage
WritePage
Writes multiple bytes starting from the specified address. Returns number of bytes written, or 0 on error.
- ULONG Address
- BYTE Data
Buffer containing data to write
- UINT Count
Number of bytes to write
Device Settings
Device Address
I2C device address bits (A2, A1, A0). Default is 0x50 (0b1010000). For 1M devices, use two component instances with addresses ending in 0 and 1.
Device Type
Select the FRAM device type
Memory Size (bytes)
Calculated memory size based on device type
Address Bits
Number of address bits for selected device
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Stop Delay
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not a 10ms delay between an I2C stop event and the next I2C start event.
Baud Select
Baud rate to be used
API
Specifies the API component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_FRAM_MB85RC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FRAM_MB85RC.fcfx
