Component: Thermocouple (MAX31856) (Environmental)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Environmental
Thermocouple (MAX31856) component
Component to interface the MAX31856 IC from MAXIM. Uses a standard 4-wire SPI interface to connect to the IC and collect the temperature. Compatible with different thermocouple types.
Configures the SPI bus ready for communications.
ReadReference_Float
ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
- FLOAT Return
ReadReference_Int
ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
- INT Return
ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
- FLOAT Return
ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
- INT Return
Sample
Sample
Reads the memory of the MAX31855 IC and checks for errors. Must be called before any of the Read functions. Returns: 0=OK, 1=Open Circuit, 2=Under/Over Voltage, 3=Out of range
WriteColdJunctionOffset
When Cold Junction Compensation is enabled mode this macro allows you to define the offset temperature of the cold junction.
- FLOAT OffsetTemperature
Range: +/- 7 Degrees
WriteColdJunctionTemperature
When Cold Junction Compensation is disabled/external mode this macro allows you to define the temperature of the cold junction.
- FLOAT Temperature
Range: +/- 127 Degrees
Thermocouple Properties
Thermocouple Type
Specified the thermocouple type used with the sensor IC
Averaging
Select the number of samples used to provide stable readings.
Conversion Mode
Notch Filter
Choose the frequency of notch filter
Allows the chip to automatically perform cold junction compensation to try and get more accurate temperature conversions. Internal - Uses internal temperature sensor External / Disabled- Uses SetColdJunctionTemperature macro to allow for external temperature compensation.
SPI Properties
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMAX31856.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMAX31856.fcfx
