Component: Thermistor (EBM003) (EBM Modules)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 1.1
Category EBM Modules
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. The component is also used with the EBM003 module, in which case the extra circuitry is already included. Default calibration is for the EBM003 module.
Please click here to download the component source project: FC_Comp_Source_EBM003v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM003v1.fcfx
CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
- UINT ADCValue
ADC Reading to be converted
- INT Return
GetADCValue
GetADCValue
Returns the Raw ADC value from the Analogue Channel
GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT Return
GetRealTemperature
GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT Return
SetChannel
SetChannel
Set the ADC Channel
- INT ChannelID
SetTemperature
SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Temperature
Zero to one value - representing min-max of the sensor.
ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
VRef option
Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
ADC Bit Resolution
Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
-25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
A text label to help you identify the component on the panel.
