| Author
Matrix Ltd.
| Version
1.3
| Category
Comms: USB
USB Slave component
Component to create and communicate using a generic USB communications profile. Has the ability to allow the device to be a slave to the PC. Compatible with simulation and USB enabled microcontroller devices (PIC/dsPIC).
Please click here to download the component source project: FC_Comp_Source_USBSlave.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_USBSlave.fcfx
CheckRx
CheckRx
| Called to check if there is any incoming data waiting to be received. Returns the number of incoming data bytes. Only needed when not running the slave service.
- BYTE
GetByte
GetByte
| Retreives the byte at location Idx from the incoming data buffer.
- BYTE
Idx
| Specifies the location in the incoming buffer
- BYTE
GetString
GetString
| Retreives a string of data from the incoming data buffer starting from location 0 and incrementing up to the NumBytes parameter.
- BYTE
NumBytes
| Specifies the maximum number of bytes to try and read.
- STRING
| Starts up the USB communications and attempts to enumerate. Returns 0 for a successful startup or 255 for a enumeration timeout.
- BYTE
RunSlaveService
RunSlaveService
| Stalls the microcontroller and waits for an incoming message from the USB, when a message is received the macro defined in the USB Slave properties is automatically run. While the macro is running you can choose to send data back to the PC if you wish.
SendByte
SendByte
| Adds the byte onto the end of the outgoing data buffer.
- BYTE
Data
| Data byte to transmit to the host
- BYTE
SendByteArray
SendByteArray
| Adds an array of bytes onto the end of the outgoing data buffer.
| [[File:]] -
Data
| Data Bytes To Send
- BYTE
Length
| Max number of bytes to try and add to the outgoing buffer.
- BYTE
SendString
SendString
| Adds a string of bytes onto the end of the outgoing data buffer.
- STRING
Data
| Data String To Send
- BYTE
Length
- BYTE
StopSlaveService
StopSlaveService
| Allows the microcontroller to leave the stalled slave mode and resume its normal independant functionality. Must be called from within the slave service routine to work correctly.
USB Properties
Vendor ID
| USB VID
Product ID
| USB PID
Device Name
| USB Device Name
Manufacturer
| USB Manufacturer
Major Version
| USB Major Version Number
Minor Version
| USB Minor Version Number
Enumeration Timeout
| Specifies if the enumeration (Initialise function) can timeout if taking too long.
Country Code
| Country code used by some regional based USB devices
Maximum Current (mA)
| Maximum amount of current the USB host will provide before shutting down the USB channel.
Slave Macro Properties
Slave Macro
| Flowcode macro to call while the slave service is enabled
Macro Parameters
| Defines the parameters for the slave service macro allowing data from the host to be automatically passed into the macro.
USB Driver
Driver Directory
| Directory to save the generated device driver .inf file
Driver Filename
| Filename assigned to the USB device driver .inf file when generated.
Generate Driver
| Generates a driver file when set to Yes, Automatically jumps back to No when complete.
Instance
| Hardware instance to communicate with any connected USB slave devices.
Timeout (ms)
| Simulation host to slave communications timeout in milliseconds
| Text displayed on the I/O flasher comms component.
