API File.Buffer.WriteByte
Revision as of 13:17, 14 May 2013 by JonnyW (talk | contribs) (XML import API changes)
<sidebar>API contents</sidebar> Writes a single byte to the input stream
Class hierarchy
File
Buffer
WriteByte
HANDLE FileHandle
The handle of an open file
BYTE Data
A byte of data to write to the file
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::File.Buffer.WriteByte(filehandle, data)
