API Scope.AddPort
<sidebar>API contents</sidebar> Adds an input to the stream from a port
HANDLE StreamH
- A handle to a previously created datascope stream
ULONG PortIndex
- A zero-based port index, or a textual port name
ULONG BitMask
- The bits of the port to isolate and use
- The default value for this parameter is: -1
BOOL PackMask
- True to pack all the bits together, false to leave gaps
- The default value for this parameter is: 1
BOOL Merge
- True to bitwise-or the bits with the current data, false to append to the end
Returns true if the operation is a success, else false
- Add to a calculation icon:
result = ::Scope.AddPort(streamh, portindex, bitmask, true, false)
