API Component.Property.AddListItem
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Alters or appends a list entries text for the property by named index
Class hierarchy
Component
Property
AddListItem
HANDLE Handle
The component handle to alter the property of
STRING Property
The textual name of the property
STRING Index
The text or integer entry of the property
STRING Value
The value to update the entry with
BOOL
Returns true if the operation is a success, else false
  • Add to a calculation icon:
    result = ::Component.Property.AddListItem(handle, "property", "index", "value")
