API Connection.GetAn
Revision as of 11:08, 10 June 2013 by JonnyW (talk | contribs) (XML Import to change Variable types into Variable Types)
<sidebar>API contents</sidebar> Gets an analog value from its channel index
Class hierarchy
Connection
GetAn
UINT ChannelIx
The zero-based index of the analog channel
BOOL BitMult
Set to read the analog value as a full-width reading for the selected device
FLOAT
  • Declare a variable 'result' of type FLOAT
  • Add to a calculation icon:
    result = ::Connection.GetAn(channelix, true)
